96' Johnson 112 Spl (no Spark) On Any
N1NE1
OK I STILL HAVENT FIGURED OUT WHY I HAVE NO SPARK ON ANY CYLINDER, I'VE TRIED,NEW POWER PACK, NEW STATOR, NEW RECTIFIER.. ONLY THING I DIDNT CHANGE YET IS TIMER BASE ASSEMBLY AND ALL 4 COILS WHICH I DOUBT ALL 4 CAN BE BAD AT SAME TIME.. ANY IDEAS? I EVEN TRIED DISCONNECTING THE SINGLE BLACK WIRE TO ELIMINATE THE KILL CIRCUIT AND STILL NOTHING.... I ONLY HAVE THE ONE PLUG OFF HARNESS PLUGGED IN THAT ATTACHS TO KEYSWITCH. PLEASE HELP!!!!:confused::mad:
crb478
Re: 96' Johnson 112 Spl (no Spark) On Any
I would start by cleaning all of the connectors, and grounds. Do you have a manual? It will have specific test for your particular model. It sounds like you have already replaced just about everything.
