96 Johnson 150 fast strike J150gledb
gcalvert83
Motor has been idling a little rough, loading up at low idle like in no wake zones. Thought I’d try sea foam bake out. Mixed 1 gallon of 91 octane gas, 3 ounces of 2 stroke oil and 1 can of sea foam. Ran for 15 minutes, let cool, ran for 15 minutes and let cool. Hooked everything back up and now it won’t start!!! Primer bulb is tight, plugs are a little wet but not horrible. Opened all carb bowl drains and got fuel when I squeezed the bulb. I’m at a loss, any ideas??? Please and thank you
gcalvert83
Well, checked compression, good. Checked spark, good, checked fuel filter on motor, pretty clean. Checked and had to slightly tighten one battery terminal AND........ it started!!!! Face Slap.
