96 Johnson 150 v6 not idling
jrivera96
4/14/22 Update:
Replaced optical sensor. runs much cleaner, however timing lever still needs to be cracked to stay running. even if motor has ran for about 10 minutes. will stall if i lower the timing advance lever completely. Does not take nearly as much advance to stay on. The only other thing i noticed now that it can stay running, there is a very random cough the motor gives. happened twice within about a 35 minute span of it idling.
Where should i go next?
