cobbcfi
Thread starter- Joined
- Jun 30, 2010
- 150
Having major issues, J225txede engine, engine won't fire.. Did a spark test and bottom left and middle right bank have no spark.. 5 cylinders have compression between 100 and 110, the upper right cylinder has zero... Removed and re-installed the compression tester several times with no luck...
With all spark plugs removed, the engine will only spine about 1 rotation or less on 5 cylinders tested but upper right the engine turns and turns without issues other than the Guage reading zero!!
I know if all cylinders are around 10% of each other regardless of the number range but how the hell am I getting zero on one of them?? Is that a blown gasket or collapsed rings?? I bought the remanned power head about 5 years ago and it's been running great..
Any help would be great!!
