96 johnson 9.9-15 carb. Choke ??
Bass n Boats
Hello all, I recently bought a 15 hp carburetor off ebay, in great shape, but did not see where it said the carb had an electric choke before. My 9.9 choke was manual..my question is, how/can you convert from manual to electric. What all parts do I need. Any info would be greatly appreciated, and if you can link a video it would be a huge help..thank you
oldboat1
Believe the '96 carb/motor would use a primer system -- If so, the carb would not have a choke flapper in the front.
The electric primer ( aka choke ) is not part of the carburetor.----It is a separate item that works very well on electric start remote motors.
Bass n Boats
I understand that, tryin to figure out if I can buy a complete kit to make it work lol..my boat is a pull start
oldboat1
The original 9.9 carb has the choke flapper, but the 15hp does not
which is to say, the 15 engine (donor motor) had a primer system. If you are going to duplicate that system on your 9.9 motor with the "new" 15 carb, you will need to find all of the bits and pieces for that system. Go here to iBoats or to Marine engine or another source and look at a parts breakdown for the primer system. I am not aware of a system package you could buy, but maybe you can find a dead 15 with the system -- buy the dead 15.
raczekp1
i added a manual chocke in this type of carb. few hours of work and its done
Bass n Boats
I'll for sure look at that parts breakdown, thanks
The parts book seems to show more than one carburetor for the 15 HP model.-----Would depend on it being manual start / electric start tiller / electric start remote control.
Bass n Boats
What's the part numbers for the 2 you've found? I cant find the carb using the number stamped on it
oldboat1
Prepare to get in the weeds. That would usually be a part number for the carb part it's stamped on. The carb number is typically a tin tag held on by one of the bowl mounting screws. You can verify that you have a 15 by looking at the throat size (See Leroy's Ramblings re. 9/15 hp J&E.)
Good luck with the project. Maybe the Ebay seller will exchange for a 15hp choked carb to put on your 9.9.
How about-----436778 , 437979 , 438026 , 436779 , 439129 , 439128----listed for J15REDS
oldboat1
If on Ebay, you would need to get the seller to show (in the above example) that the carb came from a J15REDS -- would want to see one of those numbers for the carb he's selling. (And something more than a number he derived from the motor model number.)
