'96 lund tyee 1850 floor rebuild and foam replacement.
brunolund
new vs old side panel piece and new rod locker door. just waiting for o e more part before i can assemble the side panels and install!!
TCKibe1
Man, this is just what I was looking for! I've got a 93 that someone tore the floor out of. Now I can visualize the layout for the new floor. Thanks for posting this!
Sparike
TC--I used that thread also then posted under "1990 Tyee 1850 interior"--some pictures there also, hope they help ---the search function is very helpfull narrowing down what you are looking for
brunolund
glad it helped. hopefully i can get back on this project soon. as usual, life gets in the way. ask any questions you have, and i’ll try to help.
TCKibe1
Bruno, 2 questions. How many sheets of plywood did you use and did you use all of the foam in the 80 lb kit.
brunolund
think i used 6 sheets of plywood, but i am replacing every single piece of wood in the boat. and 2 more 3/4” sheets for the transom. i used 4/5ths of the 80 lb kit. i didn’t get to the foam under the rod lockers, as i found dry foam around them, and i didn’t want to take any more rivets out from the side of the boat. but rear of the rod lockers and everything under the floor got replaced.
TCKibe1
Thanks, how was the aluminum on your transom? Mine was full of corrosion perforations. I skinned over it with a piece of 5052. I'm sure I'll have more questions when I get to the front of the boat, just doing the back so we can use it.
brunolund
looks good. i had no corrosion, but i did get a few old mounting holes welded up. left some very minor distortion, but it’s all good.
brunolund
got a bit more done!! side panels are built, although i need to iron out some wrinkles, but otherwise good. and installed the rear deck.
brunolund
also found a great deal!! $50.00! took about ten mins to clean up with some hydrochloride acid hull cleaner.
brunolund
got the rear deck panel installed!! had to paint individual screw heads because i forgot there was a board under this deck. but sandblasted the head and epoxied then painted the heads with a tiny brush.
brunolund
polished up the side interior rub rails. came out pretty good!!
brunolund
console front/ sides, and bow side compartments cut and first coat on.
brunolund
building the console front/ sides
brunolund
surprisingly difficult and time consuming. but got them done. now to install them!!
brunolund
got them in! needed a little tweaking, and i still need to screw down the center pieces, but gotta get more screws!!
brunolund
got the rod lockers in! coming together slowly. nice to have these bigger pieces out of the way in the shop.
brunolund
new bow side compartments, with the old one beside. also trying to figure out how to fix/ or remake the dash panel inserts. think i’ve got it figured, but will see how it turns out.
brunolund
new and old dash inserts.
