'96 lund tyee 1850 floor rebuild and foam replacement.
brunolund
4 bolt to remove steering rack, and more wiring. instrument cluster came out in one piece with all wiring attached. only had to cut 4 wires. i just cut them at a butt splice, and will replace with proper plugs when reinstalling it.
brunolund
drivers console removed and starting on second livewell. i have more pictures showing screw locations if anyone is interested.
brunolund
livewell 2 removed and wiring visible. should be fun cleaning it up more.
brunolund
front of deck coming out and what it looks like empty!! easy to see the fading on the carpet now. next is to remove the outdrive and motor.
brunolund
engine coming out. lots of room to work at least.
brunolund
more
brunolund
and it’s out. had to build a quick stand so it didn’t sit on oil pan.
brunolund
[No message]
brunolund
that’s a pile of wire!!
brunolund
[No message]
brunolund
[No message]
brunolund
looking at how to get the cap off. looks like a lot of rivets. both solid and blind. oh well. out comes the drill. good thing don s has that info on the rivets as a sticky!!
brunolund
this is how they should come out. if you drill in the center. most were good, but i did miss center a few times!!
brunolund
when you drill off center, just don’t go very deep, and knock the head off with a small chisel. they come off pretty easy.
brunolund
and the cap is off.
brunolund
some more foam from port aft corner. seems dry so far. but i know the transom is gone under it.
brunolund
ther it is!!
brunolund
[No message]
Sparike
you are not alone--just started tearing out the interior of my 1990 Tyee 1850, I'll see if I can figure out this picture thing
GA_Boater
Howdy.
When you get pics working, start your own thread. Click on Forum Help in my sig and look at the Photo Tutorial.
