pinellas50
Thread starter- Joined
- Aug 10, 2009
- 207
I need some direction here. I had the family out fishing this weekend. On the way back in we pulled into one of the fingers off the ICW and threw anchor so the kids could swim. When I started the motor back up I happened to look at the tell tale and it had a very weak stream. On the way back to the ramp the stream continued to be extremely weak even at running rpm. It did not overheat.
History: I replaced the entire water pump housing and base plate at the beginning of last season. The motor was peeing like a college kid at a keg party. Prior to the replacement, the pump base was extremely corroded away and leaking badly but it still had a good stream from the tell tale.
I put the motor on muffs and started it. I have water leaking out of every conceivable hole on the lower unit. It's coming out of 2 drain holes and up through the hole where the shift shaft goes. There was no water intrusion into the gear oil.
I pulled the lower unit and.........nothing looks to be wrong. The water pump housing still looks brand new. I don't see how that much water could be leaking from this water pump. I looked up the water pipe into the bottom of the motor and it looked solid.
What am I over looking here? What should I be looking for?
