96 Mariner 200 EFI surging loss of top speed and wont hole shot
Adam21986
New member, this will me my first post. I have a 96 Mariner 200 EFI on a 96 Procraft SP200 bass boat. I am a tournament bass Fishermen and run the boat at least twice a week hard. The oil injection was removed when purchased in 96 (I bought from original owner with 98 hours) I run rec fuel and mix 50:1 plus some TCW 3. Friday I had accidentally went heavy on oil mixture in tank 2. I always run heavy but this was more than usual. Saturday after a full day on Okeechobee ran roughly 55 miles, on my way in I switched to tank 2 about 3 minutes later the motor began to surge and also struggle to hole shot. It was intermittent, I could run up to 68 mph and then it would bog down to 60 then surge back up. It did this at all speeds and rpm. Never died. I went home and pulled the plugs, they were fouled. I put new plugs and ran it Sunday, same problem, intermittent surging and hard to get on plane. Sunday afternoon I drained all fuel out of both tanks, cleaned VST and hp fuel pump filter (both which were clean) I by passed the fuel tank and ran 2 gallons of rec fuel 50:50 mixed with seafoam from a gas can also cleaned plugs. Monday I ran the boat again, the surging stopped but it will bog down on hole shot and not get in plane (rev to about 3k then bog down. Can get on plane with passenger on bow) so it didnt surge but would hold me at 60 mph, twice it cleared up and ran clean up to 67mph then pull me back to 60. Also it now burns (or wastes) twice as much fuel maybe more. Checked plugs, fouled again. Tested fuel pressure was at 35. I checked compression exactly at 130 on all 6. It's a clean low hour well maintained motor. I am wondering if a injector is stuck open and getting to much fuel. Ran again today same symptoms but never cleared up and harder to plane. I am considering pulling injectors and having them cleaned and tested but I wanted to check here first. Any help is greatly appreciated!! Thank you!!
SN OG373534
1996 Mariner 200 Magnum EFI
96 Procraft SP200
Faztbullet
Need to STOP running it as you can wipe out a cylinder if lean. If the injectors have never been serviced pull em an send to Brucato to have cleaned and balanced..The mechanic in a can does not clean injectors ..
Adam21986
FIXED. Problem was failed ambient air temp sensor confusing ECU. Thanks for y'alls help!
