SparkieBoat
Thread starter- Joined
- Aug 17, 2009
- 3,643
I just purchased a 1996 Evinrude 150. It has 95-100 psi on all cylinders. It is having problems starting. I removed the carbs ( o boy were they easier than my 79' 85 Johnson the bottom right nut on the bottom carb jeez wizz ) and there is a neddle valve screw behind each carb..from my knowledge of needle valves they are usually all set the same..I noticed they were different..I screwed one all the way in 5 turns..checked the next one and it was 3 turns... all 6 were way different. How many turns out should they be set???
I just got this motor and it is my first V-6..havent got a manual yet, but will soon
Thanks Sparkie
Thanks Sparkie
