9622a evinrude wont run with cover on
Rick.
Re: 9622a evinrude wont run with cover on
kmaysob: Great to hear of your success. A couple of things I would recommend. A new impeller as soon as you can get one, unless you are aware of the last time it was changed. I would also recommend changing the leg oil. Other than that, have lots of fun with it, they are good motors and very dependable.
F_R: Moose Milk!! You've made me laugh out loud again. Thanks for your insight and as always, your sense of humor. Rick.
kmaysob
i had planed on changing the lower end oil. i didnt think of the prop.
ill have to look for one. it probably is ok. it came from a co worker who took pretty good care of this motor. any way to tell if i need to replace it?
Rick.
Don't change the Prop, I said impeller. The impeller is the life blood of the cooling system and should be replaced every two to three years. You can't tell by looking at them if they are going to fail, only that they have failed which is too late for your power head. Changing the impeller is preventative maintenance. Rick.
kmaysob
idk why i automatically thought the prop. yes the impeller.i priced that out the day i got it. thanks for the advise.
jay mendoza
One thing I know that makes all 2-strokes smoke is stuck compression rings. On most 2-strokes with 2 rings, the second ring will get stuck with carbon and varnish in the ring grooves.
The second thing I have seen that makes 2-strokes smoke badly is blocked exhaust. Although this is rare in outboards, it can happen, especially if someone ran too much oil in the gasoline, or used motor oil in place TC-W rated oil.
Prolonged idling will cause the cases to load up and the engine to smoke. Over cooling, (thermostat stcuk open) will cause excessive smoking, And the idle mixture(low speed) set too rich can cause excessive smoking.
A propoer de-carb treatment will unstick the rings, and usually reduces smoking and increases compression slightly.
Rick.
jay mendoza: Good points, all of them matter. Rick.
kmaysob
hey sorry for the late replies guys. work has been crazy. i havent really done too much more to the motor yet. although i have gotten it down to starting on the first pull. still plan to order an impeller kit. ive been busy getting the trailer fixed up. the trailer wasnt originally made for this little boat. now its set up for it. its been painted, the wood replaced, new carpet,moved the winch closer,repacked the bearings...ect
