FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Did this motor, Johnson 65 hp 1968, Model VXL14B come with a different prop other than part #307313 10 x11 pitch?? thanks Mars Bar. I see a listing for a 10 x 12?
The 10 X 11 is is only one size smaller than the 10 X 12 the highest pitch.
What was the pitch on the 50? The 65 ha a 1.70:1 The 50 I believe is a 2.42:1 This would probably give the 50 a little edge out of the hole
What was the pitch on the 50? The 65 ha a 1.70:1 The 50 I believe is a 2.42:1 This would probably give the 50 a little edge out of the hole. the 65 is 225 lbs,the 50 is 185.The rpm range of the 65 is 4000-5000, the 50 is 5000-6000 From the 1968 brochure.
Prop calculator says that at 5000 with a 12" prop the 65 will do a little over 30.
The brochure does claim a max speed of 36.The 72 claims speeds to 38.
The 50 with @ 6000 with a 17" prop (the 2.42 ratio will turn a higher pitch and a 17" is pretty typical)
Speed is about 36.
Whether either motor could make their max rpm with the size props I quoted would depend on the boat and a healthy motor.
I dropped the 50 because it was an ESL and a friend told me they had a reputation for blowing the top, plus the solenoids in the lower unit and that switch in the control box all added to my decision. Bought the 50 for$250 sold for $400, bought the 65 for $500. I thought that I'd get more uummph! out of the 65 for pulling a tube with my" larger Daughters". Hey thanks for the knowledge your pretty wise on this subject.
You're probably better off without the "electric" shift but if the 65 has the magneto distributor parts may be scarce.
The V4s are said to have good low end grunt. You may want to check the compression.At least 100psi.
If compression is low sometimes a decarb treatment with something like Sea Foam helps free the rings.
Be sure the throttle opens all the way. Antivent plate about even with the bottom of the transom.
To evaluate your setup you need a tach and a gps to get us the wot rpm and speed.
