97 350 Mag Power steering leak
NHGuy
I'm getting Power Steering fluid on top of my intake, which is concave and silver. I'm comfortable that it's PS oil cause when I lost power steering I added some red atf and that's what color the oil on the intake is. it only ran a few minutes. before I lost power assist again.
Where could it be coming from? I did a visual check and didn't find any obvious source. I wonder if I have a leak in the PS cooler that's right behind the distributor.
I'd have finished checking, but it started to rain while I was out there.
It's starting to clear up. Going back to it now,
clean everything....then fire it up and follow the spray.
Ayuh,.... It Could be, but that's the low pressure side,.....
A spray makes me think high pressure,....
Only way to find out is fire it up, 'n Look,....
NHGuy
Yup, once the rain let up I went out, added some fluid to the reservoir and started it and hiss, pink spray from the return line that goes into the cooler.
There was enough line that I was able to cut it back 2 inches and reclamp in a couple of minutes.
The cleanup however took hours and still isn't good enough.
I think I musta bumped that line when I put the head on. The line had 2 little smiles in it. Kinda like a smaller version of the cuts that happen to golf balls when you get them with the edge of the club.
NHGuy
BTW, I did not clean everything til after the test, cause I knew I'd be cleaning once I found the problem.
