97/98 Evinrude 130hp
rusk
Consider a boat with this engine. It is a carburator V4 engine.<br />Is it a good motor or are there any known errors ?
Solittle
Re: 97/98 Evinrude 130hp
Welcome rusk!!<br /><br />OMC V4s are solid engines. Condition and maintenance is the key.
rusk
OK, but the lower units and metal hardening isn't the best on these i've heard. But that is perhaps just a rumor.
phatmanmike
have you ever actually owned a evinrude/ johnson v4?<br /><br />metal hardening?<br />lower units?<br /><br />i have a 1976 115hp v4 that'll run circles around any 80's or early 90's yammy! you want metal probs, get a mid 80's yammy.<br /><br />omc v4's are world famous for a reason! they kick azz!!!!!<br /><br />ive owned 90hp v4, 85hp v4 and 2 115 v4!!!!! all rock solid
rusk
Haven't owned a OMC V4, but have been told by mechanics that it was a problem. Did a search for the topic now and found that others had this problem to :<br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=28;t=001085#000000 <br /><br />It's teeth's missing in gears because of a manufacturing defect on hardening pinion gears. Just wander if anybody know if the 97/98 Evinrude 130hp is affected.
JC1933
Myoutboards Hi,<br /><br /> I have a1995 130 johnson do you think it might have this problem, thanks---J,C,
Solittle
I have never heard of lower unit problems with the V4s other than those with electric shift (& I had one of those). I have has a 75, a 100, a 140 & 2 110s & never a lower unit problem. Unverified rumors only cause problems.
JC1933
Thanks SoLittle,<br /><br /> I only ran this motor about 10 hours since i bought it last year, i finde light metel specs on the drain plug magnet, i was tolde this was normal<br /> thanks for the reasurance--(Claude). :D
phatmanmike
there will be SOME MARGINALL metalic dust. its metal against metal in there. get a magnetic drain plug screw and be done with it!
JC1933
Thanks myoutboards,<br /><br /> I do have the magnetic drain plug.<br /><br /> ( Claude,)
