toneybrown
Thread starter- Joined
- Jul 1, 2013
- 104
Hey everybody. Just thought I would stop in and check the vast knowledge here before I seek any solutions. I have a 97 Nitro with a 97 Force 120 outboard. For the most part the engine has been good to me, but I have a frustrating problem.
The boat sometimes dies when idling, and normally requires me to give it throttle in neutral to start easily. In addition, once I start it, if I don't give it some throttle before engaging the drive the motor stalls and dies. If I start it with throttle and get the rpms up a little, it will idle higher when I put it in neutral and then will shift into gear without stalling out.
My question is what could be the cause of this issue? I have had the boat close to 3 years now and I think the stall issue has gotten worse from when I first had it, but it would still stall even when it was new to me.
Any an all suggestions to fix this frustrating situation would be great. The motor seems to run fine other then this one issue.
