Went to raise my 97 Force 120 yesterday and it won't lift (motor does not even turn) but it will go down. Switched relays and only down works still. I hooked my multimeter to the blue & white wire (per SELOC) at relay plug and I get juice when down switch is hit. Hook to green & white wire at plug and I do not get juice. I'm assuming the wires were installed in reverse since SELOC states blue/white wire powers up directon and Green/White powers down. In the process of trouble shooting I dumped most of my fluid whivh was a red liquid. My questions are:
1. What is the proper fluid for this unit? - oil was red.
2. How do you remove the switch from the handle on my remote control. - It's a Quicksilver remote control. I didn't see any reference to it in my SELOC manual.
3. What is most likely place to look for my lack of power to the green/white wire?
Any help would be appreciated!
