Any ideas to make run smooth at around idle.new plugs are in.
R rcpilot Seaman Apprentice Joined May 17, 2003 Messages 34 Apr 13, 2004 #1 Any ideas to make run smooth at around idle.new plugs are in.
eurolarva Rear Admiral Joined Jun 24, 2003 Messages 4,182 Apr 13, 2004 #2 Re: 97 Force 40 tuning Can you post the year and the model number. Also if you have any history about the motor would be helpful.
roscoe Supreme Mariner Joined Oct 30, 2002 Messages 21,852 Apr 13, 2004 #3 Re: 97 Force 40 tuning Overhauling and adjusting the carb should do it, provided you have adequate compression and spark.
R rcpilot Seaman Apprentice Joined May 17, 2003 Messages 34 Apr 15, 2004 #4 Re: 97 Force 40 tuning Any thing to look for in rebuilding carb
R rcpilot Seaman Apprentice Joined May 17, 2003 Messages 34 Apr 15, 2004 #5 Re: 97 Force 40 tuning The motor has great compression and runs very well.Its just a little jumpy at idle
eurolarva Rear Admiral Joined Jun 24, 2003 Messages 4,182 Apr 15, 2004 #6 Re: 97 Force 40 tuning Just buy a rebuild kit for the carb. Clean it out good with carb cleaner. Also might want to buy a rebuild kit for the fuel pump. Total cost for both kits is under 25 dollars. You can get them from NAPA
O Oldsaltydog Petty Officer 1st Class Joined Jan 27, 2004 Messages 322 Apr 15, 2004 #7 Re: 97 Force 40 tuning I suppose you have already adjusted the carburetor mixture and idle screw as the first step.
