Mac3
Thread starter- Joined
- Jun 18, 2008
- 105
I have had a low water reading recently with occassional engine warning, now I have no reading at all at idle with warning light on when in water immediately but not at all when I use the muffs or flush from the top. I removed the lower unit and checked the impellor which is only about 10 hours old, I fixed the hose to the water intake, removed the thermostats and it gushed out the tell tale. I started the engine with the lower unit removed, dunno if that's okay or not, and still no reading. Before I hand it over to the experts is there anything else I can check?
cheers
David
cheers
David
