steelhorse1369
Thread starter- Joined
- Aug 27, 2016
- 9
After many hours I guess im stumped I have been around boats all my life have never found a motor i couldnt make run. This is a 97 Johnson 40 hp, only had it about a year dont know the history of the motor. its on a pontoon was running fine and lost power at full throttle went down to near idle ,it was immediately turned off and checked ,it was not overheated all looked. when tried to restart it fired and died would not stay running.First thing you think fuel issue, it had a vro pump with the oil line cut and plugged with a bolt, didnt like that to start with so started there converted to a standard pulse pump mounted on on the block, pulse for the vro was properly plugged at the motor,fuel and vacuum lines all replaced, still same result still thought has to be fuel, noticed fuel dripping from front of the carbs, got carb kit and cleaned /rebuilt carbs reset floats set idle screws at 1.5 turns from soft seat same resul
