97' Ocean Pro carb rebuild
dingbat
I need to purchase carb kits and it does not state if you need one kit per carb or per pair of carbs. It also does not state what's included in the kit. Do I need to purchase other parts beside the kits to rebuild the carbs?
angus63
Re: 97' Ocean Pro carb rebuild
Kit#0436852 if it's a 150 hp <br /><br />Has everything for all six<br /><br />If you have a different model, post the model # and I'll give you the kit #<br /><br />Good luck
seahorse5
You will need either 4 or 6 kits depending on the number of cylinders on your motor.<br /><br />If you have to clean out the recirculation valves, you will need intake manifold gaskets also.<br /><br />First of all, obtain the factory manual to see and understand the parts and procedures required to service the motor.
dingbat
The motor is a 200 V6 and it calls for kit number 0437327 but no where does it state what's included in the kit. I have a manual but without knowing what parts are contained in the kit it makes it hard to get your shopping list together.<br /><br />I guess the questions is do the carbs really need rebuilt? The motor idles well on a hose but every once in a while it will miss or vary a few rpm before continuing on like nothing happened. Under load and it will idle all day without missing a beat but then again that was at 1000 RPM and not the 800-900 RPM it idles on the hose.
angus63
The BRP website has a parts list which will tell you qty of carbs it supplies.
