j_martin
- Joined
- Sep 22, 2006
- 7,474
Re: '97 V6 135 Merc too much oil in top carbie
After about 5 minutes, the pressure should be gone. It will have about 2 lbs pressure on it while it's running and shortly after.
If it doesn't bleed off in a reasonable time, replace the check valve to the crankcase, low starboard side near front.
The other valve should allow free flow of oil, but if the supply gets pinched off allows atmosphere to enter after the suction gets to about 2 lbs. That is so that a restricted line or disconnect at the boat tank will not prevent the oil pump from withdrawing the reserve oil from the engine tank.
The different fuel pumps differ widely in appearence. If the kit parts look like they might fit, it's the right one.
hope it helps
John
Righto- fuel pump kit finally arrived today. The dealer supplied me the kit with part no 21-857005A 1. This differs form the one sugested by achris whom said I needed 21-42990A10. I've searched around the web and I think I may have been supplied the incorrect kit. The engine is a 135HP 1997 V6 Carb serial no 0G469384. Before I open the kit, can anybody please confirm this is the correct or incorrect kit?
Also, after running the engine for a few minutes, when I remove the cap off the main oil bottle, I can hear a release of pressure, like air rushing in. This would probably mean the check valve needs to be replaced yeah? I might as well do the fuel pump while I'm at it.
hope it helps
John
