Dave willett
Thread starter- Joined
- Oct 31, 2021
- 2
HELP!! My motor has intermittent start/ crank.
My motor has never left me stranded until last fishing trip. I pulled into a cove, fished for about an hour and then when I decided to try a new spot, I turned the key, boat turned over strong, but didn’t fire up right away. I tried to turn the key over the second time, but it did absolutely nothing. I tapped on the solenoid and starter to see if that would help and nothing. I took the solenoid and starter out to test them and they seemed fine, so I put everything back and the boat turned over and ran fine until I shut it off and it would not turn over again. I replaced the starter and solenoid with brand new parts and boat started right up, but when I turned it off, it will not turn over again, it simply clicks or does nothing. If I disconnect all power and let it sit overnight, reconnect it, then it will turn over, but if it doesn’t fire first time and I turn the key again it won’t turn over again? Any input would be greatly appreciated!
