chiefcatchemall
Thread starter- Joined
- Jul 24, 2009
- 197
Hey all, I just bought a 16.5 ft alumacraft fishing boat with a side console with a 1998 evinrude 30 hp 2 stroke on the back of it. It fires right up no problems. It idles down nice as well. This was my first time out with it and I noticed a problem. If I let the motor idle or if I trolled as slow as I could do I noticed that when I went to put the hammer down it would skip like hell and wouldn't take off like it should. It was real bad. And it would happen everytime I let it idle or put it into gear and went as slow as I could. Again, it would run fine when doing this but then when I went to gun it it would skip and shutter like hell. However if I put it back into neutral and reved it up 2 or 3 times in neutral then put it into gear and gave it full throttle it would take right off just fine. Once it's running wide open it runs like a top. I just want to get this one issue straightened out. Initially I thought maybe the plugs were loading up and hat I mixed my oil too rich but it wasn't the case. The plugs looked fine and for good measure I threw a new set in and it still was doing the same thing..
