98 4.3 GL Fuel Pump Connector
Jprevat
Hey all! I have owned this boat for a few years and never knew anything was wrong until it cut off on me on the water and just refused to fire again.
Turns out the harness connector for the fuel pump no longer stays connected to the pump. It will just slip off on a whim.
I zip tied it to get me on the trailer but I want to replace the plug.
Anyone know where I can order a replacement plug without the complete harness?
Thank you in advance!
Jprevat
Thank you for that link. I was finding different plugs and one was a fuel injector plug so thank you for pointing me in the right direction.
Bt Doctur
if only a fuel pump then any automotive 2 conductor plug will work ,
Jprevat
I had no clue it was a universal type of plug. I went ahead and order a new plug so hopefully it wont be dying on me anymore.
Nothing worse than pulling off from the dock with some friends and have it fall flat on its face after running great all day.
Jprevat
I dont have the wire leads off of the fuel pump. It is a stationary hard month on the fuel pump. The thought had crossed my mind to directly wire it and bypass the plugs but thought this solution may be more stable.
Jprevat
Just to update: new plug wired in and found my fuel pump was dragging so I replaced it too. Spent all afternoon on the water and everything went really well.
