Mike@mpr82
Thread starter- Joined
- Jul 27, 2020
- 3
I need help. I have a 1998 5.7GSIPBYCCE engine.
a little history. Last year after 1300 hours On engine I had it replaced with long block reman by Volvo. Every thing was going well till late in season when boat died and would not restart.
somebody mentioned The fuel relays, Possibly being bad. further investigation I found the Sockets of the Relays for fuel pump appeared to have a oily substance in them. I assumed the substance was from cleaning old engine prior to removal. Cleaned relay plug where they plug into sockets, Engine started.
Logged about 4 hours and it happened again. Cleaned socket again. After third time of cleaning fuel relay sockets I am thinking The oily residue is coming from relays. R/R relays. Volvo marine OEM relays are sealed
Now unfortunatly boat will not start. Tried old relays Still not starting either.
I was able to apply 12vdc directly to low pressure pump. It spun up. When I tried to start The engine Normally with key, it started onE time. And no more. Back to no start.
