FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have a 1998 60hp 4 stroke that was overheating and putting out very little water out the weap hole. I changed the impellor still didn't fix it. Any suggestions on what I should do next.
Check it for a sticking thermostat, Erich.<br /><br />You might also try backflushing the cooling system and hooking up a garden hose to the "engine off" flushing port to see what sort of flow you get if you bypass the pump and engine feed tube.<br /><br />The '98 model cooled the intake manifold and crankcase before circulating water in the block and head. Those cooling routes were eliminated in the '99 and later models. You might check with your dealer to see if there was an update to convert your '98 to that configuration.<br /><br />Good luck.
