98 75hp Mercury Force misfire
Rich49
Have a 75hp Mercury Force 1998. Runs smooth at an idle when increasing the throttle it seems to misfire every so often. Purchased the boat and motor last year and didn’t have problems the few times it was out. It is very easily flooded. Any thoughts on the misfire? Is this a timing issue? Have spark and fuel.
Tydad88
Following i have same motor same issue i just rebuilt my carb got new cdm modules and plugs and wires i did have gas leaking out my carb before rebuild last year ide get a nice idle but would hesitate till about alil over half throttle then take off like i floored it and then it would cut out at higher rpms as well no popping or backing fireing so im thinking fuel delivery issue
Tydad88
Following i have same motor same issue i just rebuilt my carb got new cdm modules and plugs and wires i did have gas leaking out my carb before rebuild last year ide get a nice idle but would hesitate till about alil over half throttle then take off like i floored it and then it would cut out at higher rpms as well no popping or backing fireing so im thinking fuel delivery issue ill update when i take it out next weekend
roscoe
First things I would look at:
Water in fuel (replace with new gas)
Tear or holes in fuel pump diaphragm (easy rebuild)
Loose or partially broken wire in ignition system.
jerryjerry05
Try the starting fluid test: start motor, spray SF around the intake side of the motor, under the pack and coils and under the carb.
If spraying makes any difference?? then the motors sucking air somewhere???
Honorary Supreme Mariner
Run with a timing light , one cylinder at a time.-----See if it is an ignition issue or something else.
Rich49
Thank you for the replies. I am the wife asking questions. I will do my best to deliver the outcome as he works on it. He is pretty hands on but a boat motor is new to him. Can a trigger go bad?
jerryjerry05
Yes the trigger can go bad but these don't usually.
This might not work for you???
MISS AT ANY RPM: 1. Disconnect the Yellow wires from the stator to the rectifier and retest. If the miss clears, replace the rectifier. 2. Disconnect the idle stabilizer (advance module) and reset the timing between 23-25 degrees Wide Open Throttle. If the problem clears, discard the idle stabilizer as it is not needed. 3. In the water or on a Dynameters, check the DVA output on the Green wires from the switch box while connected to the ignition coils. You should have a reading of at least 150V DVA or more, increasing with engine RPM until it reaches 300- 400V DVA maximum. A sharp drop in DVA right before the miss becomes apparent on all cylinders will normally be caused by a bad stator. A sharp drop in DVA on less than all cylinders will normally be the switch box or trigger. 4. Connect an inductive tachometer to each cylinder in turn and try to isolate the problem. A high variance in RPM on one cylinder usually indicates a problem in the switch box or ignition coil. Occasionally a trigger will cause this same problem. Check the trigger DVA voltage (see NO SPARK OR INTERMITTENT SPARK ON ONE OR MORE CYLINDERS above). 5. Perform a high-speed shutdown and read the spark plugs. Check for water. A crack in the block can cause a miss at high speed when the water pressure gets high, but a normal shutdown will mask the problem. 6. Check the triggering and charge coil flywheel magnets for cracked, broken and loose magnets. 7. Rotate the stator one bolt hole in either direction and retest.
