98 evinrude 200 water control valve
Sparker1
Im needing help with i believe is the water control vale. I replaced the water pump and got a steady stream up to the water control vavle but just a little water out off the tell tale side, and barely anything going to the heads, so i believe the water control valve is bad. I read its been discontinued and theres a upgraded part? Any help would be appreciated
Faztbullet
Your valve is working as designed.... and no there is no upraded part. Just a cooling conversion
