I just rebuilt powerhead on my 1998 Johnson 115 spl v4 crosslow. Motor run great but I have a water leak behind the front cowl to exhaust housing cover when the motor is running. After closer inspection I found the water was comming from the area where the 7/16 bolts are that connect the upper exhaust housing to the lower exhaust housing at the front of the outboard where the transom bracket is.
I retorqued the powerhead mounting bolts and don'y believe it is comming from there.
Where is it coming from. I have a factory OMC shop manual for the outboard and don't see how it could be coming from there. I used gasket sealer on the inner and outer exhaust covers and install the powerhead gasket dry as the manual suggested.
Any help would be greatly appreciated.
