4winnsskipper
- Joined
- May 9, 2007
- 204
Re: '98 Mariner 150 mag efi stumbles/dies for first 5 minutes then runs like champ
what are my switch boxes?
Trying to speed read through all of this, did you rebuild/check the mechanical lift pump? I noticed that the port side plugs were the most wet. The mechanical fuel pump is on the port side, I would take the mechanical fuel pump off the block and with a pair (meaning qty. 2) of vice grips, GENTLY put pressure on the square fuel pump housing (trying to simulate the fuel pump having even torque) where the two bolts would go to the block. Prime primer bulb and look at the pulse hole on the back of the fuel pump (where the backside attaches to the block). If you see any fuel coming out of that hole, time to rebuild the fuel pump.
the motor is an efi engine, the mechanical fuel pump simply fills the VST tank where the high pressure pump pressurizes the fuel rails, then the fuel injectors do the injecting.
Swap the plug and see if probem follow it, that coil fire 2 cylinders at the same time so if coil was defective it would show on other cylinder that coil fires. Could also bee a bad wire from coil or burnt inside plug boot.Think I have a bad coil,
