98 OX66 225 Primer bulb does not get hard and floods motor
69airwolf
98 OX66 225 Primer bulb does not get hard floods motor very hard to start. if I do not pump the primer bulb engine starts easy but still runs rough at low RPM
motor runs rough at idle and low rpm , runs great above 2400 RPMs
LP pumps replaced and 02 sensor cleaned last summer
jdupree
Re: 98 OX66 225 Primer bulb does not get hard and floods motor
Double check your LP pumps. I know you said they have been replaced but those symptoms are what I had when mine went bad.
69airwolf
Ok I'll check the LP pumps
there not even a year old , I put the date on the pump when I replaced them 8/20/2012
anyone else have the LP pumps go bad in less than a year ?
Capt Ken
If the needle and seat is leaking in the VST tank, it will flood fuel into the intake thought the overflow lines
69airwolf
how do I test the needle and seat ?
lawcki
Replace the seat and needle in the VST
69airwolf
pulled VST apart removed float and needle valve , cleaned everything , (not that it was very dirty,)
put it all back together.
pumped the primer bulb , it now gets hard
now I have to go to the lake and see how it runs
