ahicks
Thread starter- Joined
- Sep 16, 2013
- 3,957
Guys,
Looking for ideas on how to remedy this problem. It seems like if I use the choke while cranking the engine, even for a second, the engine gets a bucket of fuel dumped into it, without even a single pop or attempt to start.
The ONLY way I'm able to start it (and then not totally reliable, maybe 90%) is to squeeze the primer bulb until it's hard, turn the key on, engage choke for just a second, THEN crank. If it's going to start, it will do so immediately.
Once flooded, the plugs will need to removed, dried with compressed air, and reinstalled. Once this is done, and the starting procedure repeated, then it will start.
What I've done-
VRO "stuff" removed/disabled
New Fuel Pump
Carbs cleaned (twice)
New fuel line w/ends
The engine runs perfectly (from idle to WOT) once started. Flooding issue occurs ONLY at cold start - after not running for a few days.
Is there supposed to be a restrictor or orifice in the primer system that restricts the fuel flow when engaged? If so, where is it? I've had outboards for over 40 years, and never had an issue so challenging. I had this one for a couple of years when this crap started, so I know it's not normal.
What am I missing? Thoughts?
Thanks, -Al
What I've done-
New Fuel Pump
Thanks, -Al
