trobinson017
- Joined
- Sep 12, 2004
- 183
Hey all! Ran my motor 3 weeks ago, just fine. Last week had temps below freezing, now back up to high 60's/low 70's (Tampa, FL). Yesterday I had problems starting it. I dumped my fuel/water separator and there was indeed water in the fuel. This happens when the poly tank expands and contracts due to temperature changes causing the seal around the sending unit to open a bit. My mechanic says this is common with poly tanks and not to worry as long as I have the f/w separator. Anyway, after clearing out all the water and getting clear, clean gas I still can't get the motor to run for more than a minute or two. And during those 2 minutes it runs very weak, never really getting to full idle speed. Eventually, it just sputters and dies. But I can fire it right back up, yet the process repeats. I changed out the fuel filter but that made no difference.
Any advice on what I should check next? I'm going to pull the plugs later today to check those (they were replaced 6 mos ago).
Thanks!
Tim
Thanks!
Tim
