Re: 99 johnson 130 wont go wot
do not use NGK plugs, the motor was designed to run with Champions.
120, 130, 135, 140 (90? V4 Looper) 1994 - 2001 QL78YC .030
as said, retest, carbs can be cleaned and crud in the fuel line can reclog them in minutes. do you have a fuel/water separator.
push the key in, and it picking up, indicates a fuel delivery problem.
