99' Johnson 200hp On New Boat, Fuel Question
N1NE1
Just Bought A New Boat With A 99 Johnson 200hp Ocean Runner. The Boat Has A 134 Gallon Plastic Tank That Is More Than Half Full.boat Has Been Sitting Since 2005. Theres About 70gallons In It.should I Pump Out This Gas Or Use It. I Dont Know If I Should Mix This Will Newer Gas. I Havent Started The Motor Up Yet. Thats Alot Of Gas To Waste.
SparkieBoat
Re: 99' Johnson 200hp On New Boat, Fuel Question
thats a hard call...depends on if any additive was in fuel, you could try running some of the gas in your lawn mower, if it runs ok, maybe add a gallon of Sea Foam and some fresh gas, also maybe some water evaporator like Isopopyl.
tashasdaddy
no call at all, pump it out, flush out all hoses,and dispose of properly. adding new fuel to it will only contaminate the new fuel. borrow/buy a portable tank to use until then.
Madfisherman
Dump It.
You want the best from your new boat, so give it the best to perform with & I'm sure it'll look after you too.
