99 Johnson 50hp 2cyl? Any good?
flyingscott
The 40/50/60 twins had weak lower units. If you find one broken more than likely the lower unit is the culprit.
ahicks
Not on my radar of potential problems. Maybe just lucky or maybe this is just a salt water issue?
Honorary Supreme Mariner
Those pre 1989 lower units are also flimsy.------Simple as that.-----Gears and bearings are not robust !!!
The 2 cylinder lower unit is flimsy.----That is why 2 cylinder " commercial " engines used the 3 cylinder gearcase !!
You just need to get the correct driveshaft spline and length.----Shift rod as well.
