- Joined
- Apr 17, 2002
- 71,088
Re: 99 moomba outback Noise under load
Ayuh,... How over-full is it on the stick,..??
Before ya put another motor in that boat,...
Thoroughly check out the Fuel System...
From the tank vent, All the way through...
I'd bet ya ran lean, 'n detonated it to death... It's really hard to hear in a boat...
The Best, Quickest, 'n in the long run, Cheapest way out is a reman Long Block on a pallet....
Throw yer hardware on it, 'n go Boatin'....
Btw,... I'd rebuild the Carb, just to look it over...
More bad news. I have milky brown oil now on the dipstick. Did not have it on Sunday or Monday when I first heard the knocking sound. Checked the oil a little while ago and saw the water in it.
I think I'm in for an engine overhaul. The sound is the same as when it first happened. I think the bearing was going all year and then finally gave out. I probably damaged it more by having several people hear the sound it made, and then running it with higher octane fuel.
Possibly damaged the jacket from the rod and piston clattering about.
