GONEFUSHING
Thread starter- Joined
- Mar 12, 2011
- 4
I have a 99' 200hp oceanpro outboard that is in decent shape its been sitting up for 2 years. I've clean the carbs completely and replace the fuel lines/fuel water seperater/ and filter. I have the motor hooked up to an auxiallry tank with premixed gas 50:1. I disconnected the vro pump and plugged the oil line 3 inches from pump and made sure there was no air leaks. when i start the motor it revs up to 5000rpms real fast like i had the throttle all the way up and its in neutral. im scared to keep cranking the motor because it revs up to high and i dont wanna blow the motor. I'm having trouble troubleshooting this problem. does anyone have any ideas. Compression 105 on all cylinders and good spark on all cylinders.
