vrodrig
- Joined
- Sep 16, 2011
- 90
#1 Having a surge problem off idle about 2500 RPM's to 4000 RPM's. Idle seems to be ok, lower unit is in a barrel of water, engine temp is good, sensor are all connected and seem to be ok. Are these engines equiped with a rev limiter, is this normal when there is no load on the prop? I later used the ears on the lower unit, I put it in gear so the prop spins and it did the same thing. Just surges!
Problem #2 While the engine idles the warning buzzer beeps once about every 7 seconds it woudn't go away. Some one mentiond bad conections at the battery, so I checked and cleand them but no change. Same thing!
If any one has any ideas please let me know. Thanks for your help!
