cobalt1999
- Joined
- Apr 28, 2010
- 104
Carter P61122
I have done all of that as well. All fuel lines are clean.Try to unscrew the fuel suction pipe out of the tank. There is a fine mesh screen in the tube that may be partially plugged. Pitch the screen, put it back together then take the boat for a ride. Make sure all the fuel connections are tight and leak free.
You do not need a high pressure fuel pump with a carburetor.
Anti siphon ball has been removed. The fuel lines are clean from tank to carb. Fuel pump has been replaced. Fuel filter has been replaced.View attachment 413266View attachment 413267
First pic shows the pick up tube & anti siphon valve second pic is testing them for vacuum leaks….
Vacuum leaks in the pick up tube, anti siphon valve or fuel line can cause this problem as can vacuum leaks at your fuel filter. If you run the boat on a seperate outboard tank you can isolate these factors..
