99 yukon remote door locks not working??
ezbtr
Replaced battery in both spare and regular key chain remote, still won't unlock remotely - where is sensor at on truck to test/repair?
Thanks guys!
tomdinwv
Re: 99 yukon remote door locks not working??
I don't know where the sensor is but you may want to check your fuses.
Bob_VT
You lost the programming. Here are the instructions to re-program.
1. Locate the Data Link Port. It is located under dash drivers side. Be sure you know which pins are 8 and 4.
(Notice port is wider on top row)
2. Make sure there are metal contact pins in terminals 8 and 4. Connect 8 to 4 with a suitable
jumper wire (leave the jumper wire connected throughout the programming procedure). Make
sure you know which terminals are 8 and 4. The vehicle will respond by locking and unlocking the
doors to signify entering of programming mode.
3. Press and hold both the LOCK and UNLOCK buttons together on the first transmitter to be
programmed. After about 15 seconds, the vehicle will respond by locking and unlocking the doors.
Release the buttons on the transmitter.
4. Within one minute, repeat the previous step on the remaining transmitters to be programmed.
5. Remove jumper wire applied to the OBDII Port.
Disclaimer
jeeperman
3. Press and hold both the LOCK and UNLOCK buttons together on the transmitter to be
huh, my 99 Tahoe owners manual only mentions step three, nothing about any of the rest.
Anyways, mine stopped working too.
I replaced battery.
Still no workie.
Used key for months until I got around to it.
Decided maybe new battery was not really a new battery.
Opened transmitter and decided maybe the battery was in upside down.
That was the problem.
ezbtr
well i tried it a bit differently last night, pointed remote at dash while INSIDE, worked great!! Fixed! Thanks guys!
Now just to replace the outside door handle!!! :)
