dingbat
- Joined
- Nov 20, 2001
- 17,318
This is driving me crazy.
The boat will not idle reliably below 1100 rpm. It looses rpm over a course of 20 - 30 seconds or so. Bump the throttle and it would recover, then 20-30 seconds later the cycle starts over again. If you let it get below 800-900 rpm, it could continue to drop, you get no response to throttle bump, then stall.
I did a link and sync. The butterflies on the port side where sticking, not allowing the throttle to close all the way. I thought I had found the culprit, but no....that increased the cycle time to 5-10 minutes.
I then pulled and cleaned the carbs. Found nothing to speak of. Reinstalled the carbs and found an increase in RPM increased when I blocked the intake on #2 carb. Tore #2 carb down and found nothing but the RPM no longer rises when I put my hand over it. I sprayed carb cleaner around the carb gaskets, base of carb, etc. without a response.
Symptoms:
1. Sneezes/coughs thru the carbs on random cylinders now and then.
2. It will "miss", for lack of a better description, just about stall, then come abruptly back to life on a regular basis.
3. Drop 200-300 rpm (no discernible miss) for a couple of seconds, then bounce right back up to 1300 - 1400 rpm again (on hose). This usually happens after I "goose" the motor by manually operating the throttle arm
Outside of the idle issue, it starts with the turn of the key and runs very well.
Any ideas?
Symptoms:
Any ideas?
