A/C ON 1997 33FT FORMULA(AIR CONDITIONING)
COSMA
IF I DID NOT USE MY A/C THIS YEAR DO I STILL DRAIN IT? AND IF SO WHERE IS THE DRAIN?. JUST FINISHING UP MY WINTERIZING.FIRST YEAR THAT I OWN IT.
WillyBWright
Re: A/C ON 1997 33FT FORMULA(AIR CONDITIONING)
If the intake valve is shut, then you may not have to but should anyhow. If it is open, you do for sure. There'll be a fitting under the hull where cooling water enters. You basically force antifreeze in there until it forces the water out and antifreeze comes out the drain fitting, usually just above the waterline. Even if that intake valve is off, water will enter where it exits.
crazy charlie
Originally posted by TINO:<br /> IF I DID NOT USE MY A/C THIS YEAR
Whoooooa!!!!!!! You and I boat in the same water and I cant remember the days that I did not have my AC on.I used it more this year than ever before.What were you doing when it was 90 degrees?????????? Charlie
COSMA
swimming in the great south bay,
COSMA
so where is the drain crazy charlie ?
crazy charlie
You will have to look for the outlet or discharge which will look just like the bilge pump outlet.I think some later model Formulas the discharge is under the swim platform which is an unusual place.Charlie
