bob johnson
Thread starter- Joined
- Feb 25, 2009
- 4,306
I got a new boat..20.5 foot Lowe Ultra Roughneck Mod V.
70 " at the chine...with a 12 degree dead rise.
the hull weighs 790 lbs now..I bought a center console and a storage-helm seat to install myself..and i removed the rear bench seat.( i am repositioning the level flotation to the sides at the rear of the boat)
( the factory CC models weigh in at about 1100, but I should be less than that with no decking on my rig)
I will have flotation pods welded onto the back of this boat to let it float even shallower than it does.
I am aslo going to insatll a hydraulic jack plate so i can motor out of the shallow flats.
I dont care too much for top end, what eve rit is, that is fine, because it will be mostly a duck boat.
I have two motors that may end up on this boat
1988 evinrude 70 hp with a 13 -3/4" X 15 stainless steel prop( motor 264 lbs)
and
1997 evinrude 90hp dont know what prop is on it now( motor 325lbs)
so the boat is kinda light for its length...but I may have as many as 3 guys in it...
I will have the gas tank up front 12 gallons
I will have two marine batteries under the CC
3 guys would be about 600 lbs 100 lbs of additional gear and dog
Id like to be able to raise the jack enough to motor out of the shallows even if the prop is a little out of the water. i think i read someplace they make a CLEAVER style prop for that.
I dont need a performance WHOLE SHOT..i am not racing anyone to any place and usually it is too rough out to go at cruise speed..
so what prop specs am i needing to look at and what TYPES will help me with what my goals are
cupped ,
uncupped
ss
aluminum
cleaver
lots of pitch
smaller dia ( so as to not bang bottom)
the boat will be used around rocks often as well
dont need to get it nailed...just the choices to ponder over.
I dont want to buy three or four props and play mix and match..
I figure i might not be able to pin it down at less than 2 prop trials
thanks
bob
and
cupped ,
uncupped
ss
aluminum
cleaver
lots of pitch
thanks
bob
