ezbtr
Thread starter- Joined
- May 1, 2002
- 3,168
A cool article on using anchors from one of my safety bulletins...
ISSUE HOME > Anchors Aweigh! Anchors Aweigh!
If you're a boater, chances are at some point you'll want to set anchor and enjoy your surroundings. However, anchoring isn't just a matter of throwing an anchor overboard. First, you need to purchase an anchor designed for the type of bottom characteristics typically found in your area (sand, mud, etc.). Here are some guidelines to follow:
Before anchoring, be aware of the "swing"; of other area boats. For example, a yacht at anchor may swing out widely, so put more space between your boat and the yacht.
Secure your anchor line to something sturdy on the boat before dropping it into the water.
Drop your anchor slowly off the bow by holding on to the chain or line until you feel some slack.
Let the boat drift back while you feed out the proper amount of scope. The recommended scope ratio is approximately seven (or eight) to one. For example, if you're in 30 feet of water you'll want 210 to 240 feet of line.
Secure the line and "back down" on the anchor by keeping your bow into the wind or current to set it.
Put the engine in neutral and make sure that you aren't drifting. Reset your anchor if you begin to drift.
