Woodonglass
- Joined
- Dec 29, 2009
- 25,932
If you're rolling it's still the same. You want to do wet on wet coats. As soon as the first one is tacky enuf to allow another coat to be applied...put another coat on!!! You'll get much better cohesion between coats that way. You want to use Ultra Fine Foam rollers to prohibit orange peel. Rolling Gelcoat is NOT the optimum method of application but it can be done. If you want a bit of a texture on the deck, using a nylon roller with a medium texture can sometime yield some good textured results especially if you roll it just as it's tacking up.
