naplesbackwater
Thread starter- Joined
- Nov 16, 2013
- 12
I picked up a j30elerm really cheap and started by cleaning the carb and getting it running nice in idle. Two issues I can't figue out, as I am new to boating and outboards.
First, the motor doesn't turn off when I turn the ignition to the off position. It doesn't even shut off if I pull the lanyard. The controls are OEM.
Second, the motor is stuck in forward. Shift controls move smoothly as I have brand new cables. If I disconnect the cable, the lever moves freely, and I can see the linkage down on the lower unit moving up and down. When I removed the lower unit to change the water pump, I figured I might solve the issue. Once disconnected from the driveshaft, the prop could turn freely, but when reconnected it is still stuck in forward regardless of the position of the lever, and can't be turned. Any help is appreciated. Thanks,
-Jake
-Jake
