A little brain teaser...
SgtMaj
Ok, so here it goes... first one to get it right gets a kudos, and you should all know this one.
A boat has a ladder with 5 rungs on it, each spaced exactly 1 foot apart and each rung is exactly 1 inch high. The lowest rung is 2" above the water. The tide is rising at an even rate of 12" every 15 minutes and high-tide will be in one hour. How many rungs of the ladder will be underwater at high-tide?
SgtMaj
Re: A little brain teaser...
I knew I wouldn't be able to pull that one over on anyone here. :D
Good job EMM! You knew the boat would rise with the tide. :)
Bob_VT
Get alot of tidal water where you live?? Probably equal to our tides here in VT!!:D
i386
The devil is in the details. :D
Jerico
Depends on if he remembered the plug..... :)
Caveman Charlie
It also depends on if he had the anchor tied to tight and it's pulling the boat under.
