Stock type Melling brand lifters are $10 each at Autozone.
My bet is the lifter noise goes away after the gaskets are replaced.
The worst part of the job is unplugging everything and taking the big aluminum bracket off the front.Put a blanket on the passenger side fender and everything will lay over it out of the way.Looking at the engine it looks harder than it really is once you get started.
Good idea to replace those small rubber coolant hoses on the front while everything is out of the way.![]()
Thanks again for the feedback. I guess at this point, I'm inclined to leave the heads. Since the engines had the lifter noise, my buddy has been watching the oil and adding and changing the oil more frequently. He says the knock clears up after he changes the oil, only to return sometime later. Perhaps after it begins to get antifreeze in it????
Regarding the valve guides, perhaps they would leak less if the oil wasn't diluted in antifreeze. He also has been using some additives like Seafoam in the oil to try to fix the lifter knock which could also add to the thinning of the oil, who knows. He doesn't mind adding oil and I've insisted that he keep a close eye on everything now that I'm donating all this time and energy.
I found roller lifters on the summit racing site for 7.50 each. thats $125 for the set. I guess thats not to bad. However, I'm thinking we may be able clean the lifters simply by changing the oil and running the engine without antifreeze in the oil. So I'm thinking of not touching the lifters, like windsor03cobra suggested. Don't want to be lazy but...
We'll probably do the intake gasket next weekend. Weather permitting.
Thanks again for the help.
getting the antifreeze out of the oil MAY help with the tick noise for a while but it will come back......
Mine has been doing to for 50.000miles and as long as it goes aways withing 10 seconds it doesnt do any harm... Its not that the lifter are broke, its that the oil drains back to the bottom of the engine and the clicking is from lack of oil... the noise goes away after the oil hits the lifters....
You said that oil was leaking by the bellhousing, but before you said no external leaks.... That is why a coolant pressure tester would help... mine was leaking by the bellhousing, but it turned out to be the block heater freeze plug right by the oil filter.... but it only leaked when the engine was warm... and while driving it sprayed everywhere, causing me to think it was the intake gaskets... but with the tester i could see it without running the motor.
but get the oil changed soon, and use and engine flush product for 10 minutes before you change to help flush it.
Thanks Hoppy !!
Didn't GM have some issues with the Dexcool antifreeze, i had some service bulletin about it gelling up and eating at the gaskets ultimately ruining the engine, i seen the damage to a pickup truck at the shop with approx 100,000 on it. I guess now the recommendation is 75,000 or use the green stuff.
The truck had gelled up antifreeze in the radiator, in the block and heater core. Reason it was brought into the shop was the heat wasn't working
