a plugs just a plug?
floater212
I have a 2005 rinker 212 with a 350 mpi, I am looking to replace the spark plugs BUT they are AC 41-932 which are hard to find around here. my problem is which plug should I use? I heard someone that said the ac 41-932 were replaced by ac 41-993, is this true or should I look for something else? any help out there? thanks, jim.:noidea:
Bt Doctur
Re: a plugs just a plug?
pretty sure the MR43T would work too. The platinum tip came along with the autos. nothing special about them except the cost.
floater212
thanks FUN TIMES that's what I was looking for!!!! great! thanks again! jim l.
thumpar
I have always used NGK in anything import and Delco on US made.
Ayuh,.... Agreed,.... Nowhere in the service bulletin FT posted does it say the good ole MR43T, 'n for the Vortec heads, the MR43LTS Shouldn't be used,...
The MR43LTS IS the recommended service replacement plug on the later motors, Per the service bulletin,....
The Fancy, Expensive plugs gotta be re-gapped to work on the carbed motors,...
